跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Random restarts on iPhone 7
First time encountering this problem. I suspect the aftermarket battery which I replaced myself. I was able to use phone fine for about 6 months after replacing battery. I've read that cpu caller 0 is related to battery or battery connector.
Can someone confirm this is battery related by looking at the logs? Thanks a lot.
panic-base log
{"bug_type":"210","timestamp":"2024-10-01 17:19:38.00 +0300","os_version":"iPhone OS 15.8.3 (19H386)","incident_id":"9A4A077A-28D3-4D89-9D75-B95C1804C25A"} {   "build" : "iPhone OS 15.8.3 (19H386)",   "product" : "iPhone9,3",   "socId" : "0x00000000",   "kernel" : "Darwin Kernel Version 21.6.0: Sun Oct 15 00:18:06 PDT 2023; root:xnu-8020.241.42~8\/RELEASE_ARM64_T8010",   "incident" : "9A4A077A-28D3-4D89-9D75-B95C1804C25A",   "crashReporterKey" : "1d1ef95fe1e3572c5ddd474897cfb28b2a0d9b03",   "date" : "2024-10-01 17:19:38.74 +0300",   "panicString" : "Unexpected SoC (system) watchdog reset occurred",   "panicFlags" : "0x0",   "foregroundAppHash" : "2681261667",   "binaryImages" : [] }
panic-full log
{"bug_type":"210","timestamp":"2024-10-01 12:21:16.00 +0300","os_version":"iPhone OS 15.8.3 (19H386)","incident_id":"3D33B20A-381D-479A-8A36-0121F0CFE5C5"}
"socId" : "0x00008010",
"incident" : "3D33B20A-381D-479A-8A36-0121F0CFE5C5",
"date" : "2024-10-01 12:21:16.15 +0300",
"panicString" : "panic(cpu 0 caller 0xfffffff00d1681cc): nvme: \"AppleEmbeddedNVMeController. Controller fatal bit set. Write. ID=0x1830 ARG1=0x12 ARG2=0x0 ARG3=0x45800000 EDD0=0x10602040 EDD1=0x20100000 EDD2=0x0 EDD3=0x15120000 EDD4=0x4015093 EDD5=0x0 EDD6=0x0 EDD7=0x0 NANDV=0x1, DRAMV=0x0, SSDC=32G.\\n\" @IONVMeController.cpp:6090\nDebugger message: panic\nMemory ID: 0x6\nOS release type: User\nOS version: 19H386\nKernel version: Darwin Kernel Version 21.6.0: Sun Oct 15 00:18:06 PDT 2023; root:xnu-8020.241.42~8\/RELEASE_ARM64_T8010\nKernelCache UUID: CD36CE0B0356F65AFE5A8841F99CA9D2\nKernel UUID: D986A786-4953-350E-97CF-C0FCFF85FFCF\niBoot version: iBoot-7459.140.15\nsecure boot?: YES\nPaniclog version: 13\nKernel slide:      0x0000000006848000\nKernel text base:  0xfffffff00d84c000\nmach_absolute_time: 0x7a8d4b25\nEpoch Time:        sec       usec\n  Boot    : 0x66fbbeab 0x0007e41e\n  Sleep   : 0x00000000 0x00000000\n  Wake    : 0x00000000 0x00000000\n  Calendar: 0x66fbbef5 0x00091a6b\n\nZone info:\n  Zone map: 0xffffffe0b6218000 - 0xffffffe6b6218000\n  . VM    : 0xffffffe0b6218000 - 0xffffffe19c87c000\n  . RO    : 0xffffffe19c87c000 - 0xffffffe1e9548000\n  . GEN0  : 0xffffffe1e9548000 - 0xffffffe2cfbac000\n  . GEN1  : 0xffffffe2cfbac000 - 0xffffffe3b6210000\n  . GEN2  : 0xffffffe3b6210000 - 0xffffffe49c878000\n  . GEN3  : 0xffffffe49c878000 - 0xffffffe582ee0000\n  . DATA  : 0xffffffe582ee0000 - 0xffffffe6b6218000\n  Metadata: 0xffffffe0b3ee8000 - 0xffffffe0b56e8000\n  Bitmaps : 0xffffffe0b56e8000 - 0xffffffe0b6208000\n\nCORE 0 is the one that panicked. Check the full backtrace for details.\nCORE 1: PC=0xfffffff00da39844, LR=0xfffffff00da39844, FP=0xffffffee76413f00\nCompressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space\nPanicked task 0xffffffe2cfaa8648: 0 pages, 226 threads: pid 0: kernel_task\nPanicked thread: 0xffffffe2cfc70000, backtrace: 0xffffffefff4d3780, tid: 669\n\t\t  lr: 0xfffffff00da0dea0  fp: 0xffffffefff4d37c0\n\t\t  lr: 0xfffffff00da0dc28  fp: 0xffffffefff4d3830\n\t\t  lr: 0xfffffff00db2d324  fp: 0xffffffefff4d38a0\n\t\t  lr: 0xfffffff00db2c2c8  fp: 0xffffffefff4d3950\n\t\t  lr: 0xfffffff00d9d15fc  fp: 0xffffffefff4d3960\n\t\t  lr: 0xfffffff00da0d944  fp: 0xffffffefff4d3cf0\n\t\t  lr: 0xfffffff00da0d944  fp: 0xffffffefff4d3d50\n\t\t  lr: 0xfffffff00e04efa4  fp: 0xffffffefff4d3d70\n\t\t  lr: 0xfffffff00d1681cc  fp: 0xffffffefff4d3da0\n\t\t  lr: 0xfffffff00d14b168  fp: 0xffffffefff4d3df0\n\t\t  lr: 0xfffffff00dfb1948  fp: 0xffffffefff4d3e20\n\t\t  lr: 0xfffffff00da56458  fp: 0xffffffefff4d3f20\n\t\t  lr: 0xfffffff00d9dc6c0  fp: 0x0000000000000000\n\n",
"panicFlags" : "0x802",
"otherString" : "\n** Stackshot Succeeded  Bytes Traced 132481 (Uncompressed 330176) \n",
"memoryStatus" : {"compressorSize":0,"compressions":0,"decompressions":0,"busyBufferCount":72,"memoryPressureDetails":{"pagesWanted":0,"pagesReclaimed":0},"pageSize":16384,"memoryPressure":false,"memoryPages":{"active":35756,"throttled":0,"fileBacked":72639,"wired":13223,"purgeable":270,"inactive":12223,"free":15454,"speculative":39194}},
log is incomplete due to large file
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
looks like it could be a nand issue
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tom G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 156
