跳转到主内容
加入维修社区 - 创建账户
DualShock 4 CHU-ZCT2U 的维修指南、手册和故障排除帮助。获取自己维修 DualShock 4 CHU-ZCT2U 所需的一切。
My controller is acting up
Hello, so I have this ps4 controller that's acting up. It's been through a lot since I have a baby that drops it all the time.One day I try to turn on my controller but there is no sign of life. Tried charging it, no light. After giving it a few hits on my palm, the light started flashing but didn't connect. I tried connecting it to my phone while pressing ps button and share. Even though my phone said it's connected, the light kept flashing and didn't function. After the light turned off, it didn't turn on again. I gave it a few hits and started working again and this happens every time. It doesn't even work if I connect it via a USB cable to my ps4. What could be the issue? Is it fixable? Thanks a lot
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi!
I think it's motherboard related. It's possible that some IC is getting loose from the motherboard so you need to solder it again.
The only thing left to do is to disassemble the controller and check all the ribbon cables if they are still connected (probably they are). Then take the motherboard out and take a look at it. Maybe you can see some damage. Otherwise a motherboard replacement is required...
Please let us know how it goes!
这个答案有帮助吗?
得分 2
2条评论:
Hello! Thanks to you I found out that the main ic is the problem. Every time I slightly hit the ic the controller turns off and if I hit it again it starts working. I managed to solder it back and now it works like new. Thanks a ton!!!!
由完成的 分享
@evimatz my pleasure!! Good to hear that you were able to solve it :)!! Have a nice evening and take care!!
由完成的 分享
添加一条评论
you could try to take a toothpick or a safety pin and insert it in the hole in the back of the middle of the controller this will reset it. if this doesn't work then you would need to take it apart and reset the connection to the battery. I would check all the ribbon cables too
这个答案有帮助吗?
得分 0
1条评论:
This unfortunately didn't work, everytime I hit it very hard it starts working again but at a 1 inch drop it stops working. Dp u have any other suggestion? Thanks a ton
由完成的 分享
添加一条评论
添加你的答案
Evi Matz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,093
