跳转到主内容
加入维修社区 - 创建账户
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
Problema fps. Low fps
Ciao,
Sto giocando con la mia vecchia ps3. Ho provato a giocare a gran turismo e va tutto ok.
Su f1 2014 sto notando cali di framerate. Ho provato anche a cambiare disco ma il problema persiste.
Può essere un problema hardware?
Hi,
I am playing with my old ps3
I played with gran turismo and i noted no problems.
With f1 2014 i noted a lot problems with low fps.
I tried to change another disc(same videogame) but the problems are same.
Could it be a hardware problem?
Grazie. Thanks
Aggiorna (10/05/24)
Hi,
F1 is partial installed on the HDD.
I performed some tests with GTA and I noted zero lagging.
I tried to switch off the Mediaserver and changed the resolution at 720p.
Now F1 works very well... not perfect but it's ok.
I don't know if swap my HDD with SSD.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
It also depends on the manufacture. Some games are just more stable then other games (or optimized for the PS3). Some games are asking more from the PS3 it's GPU then other games.
Does F1 installs on the HDD (partly)? Or does it completely run from the blu-ray? Otherwise an SSD can help! It saves loading times when installed on the HDD/SSD. I would go for a cheap SSD with like 120GB of space if you are using game discs. Otherwise 256GB should be OK. This because the PS3 is loading games from the disc most of the time.
This is probably the only thing you can do.
If you want you can upload a video regarding the issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
SteR 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 122
