跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 个问题 查看全部
My dsi wont read games
one of my cusans was playing with it but wane he gave me it back it will not raed games
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
Hi i have the same problem . I don't have an sd card and i put wifi and thats when the games didn't work anymore. I tried everything and it didn't work. I even formatted settings and everything still didn't work
完成的
添加一条评论
13个答案
最有帮助的答案
Hey, the slot were the games go into is most likely damaged or needs to be cleaned. If you look in the slot, there is a door that needs to be lifted up and you can see the pins that read the game.
Shine a light into the slot and see if any of the pins are bent out of position or they have a green color corrosion over them.
If you see corrosion, then you can clean it with a nail file. Just be careful, so you do not bend the pins.
这个答案有帮助吗?
得分 4
1条评论:
i might try it
完成的
添加一条评论
Hi my DSI had the same problem, so did my sister's but hers is fixed. All she did was shake her DSI and then clean the slot with a tissue. It didn't work for mine sadly
这个答案有帮助吗?
得分 2
1条评论:
Oh yeah and what door do u mean
完成的
添加一条评论
well mine is a used one and it wont show
这个答案有帮助吗?
得分 2
添加一条评论
I'm having the same problem :(
这个答案有帮助吗?
得分 1
添加一条评论
No I found a game out side and it has a dent in it the chip is clean but my dsi xl won't read it
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem
这个答案有帮助吗?
得分 1
添加一条评论
Try putting a clothing tag in the game slot alongside the game. Yes, it does work, but it may take a few tries. It seems like it would break it more, I know, but I swear this happened to me and this was my solution.
这个答案有帮助吗?
得分 1
4条评论:
whats a clothing tag?
完成的
*sweatdrop*
Um...sometimes clothes have those tags that are connected by little plastic tabs. Just, if you keep trying to get the game to work, putting slight pressure alongside the game card helps.
完成的
this is the only one here that helped me
完成的
Did yours have blended pins or was it just dirty?
完成的
添加一条评论
Try spray compressed air in the slot. There may be dust bunnies inside.
这个答案有帮助吗?
得分 1
添加一条评论
Hello, I am a YouTuber who has this same problem. As soon as I find a fix it will be uploaded on my channel here.
Hopefully, when and if I upload the video it will help you out.
这个答案有帮助吗?
得分 0
1条评论:
What door?I don't see a door
完成的
添加一条评论
I have borrowed a dsi and simply blew into the game slot
这个答案有帮助吗?
得分 0
添加一条评论
I think DSI causes issues sometimes in reading games. You have to try it again and again and hopefully, it will help.
这个答案有帮助吗?
得分 0
添加一条评论
it could be dust in the slot. try using a cotton swab and rubbing alcohol in the slot. if that does not work, take it to a repair shop or if you know how to repair it, buy a replacement game card slot.
这个答案有帮助吗?
得分 0
添加一条评论
One possible solution is to clean the contacts on both the game cartridge and the DSi console using a soft, dry cloth. This can help remove any dirt or debris that may be interfering with the connection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gaynordante 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 59
过去 30 天: 256
总计 39,382
