跳转到主内容
Also known as the PS one, or the PSOne, this device is the slim version of the original PlayStation, released in 2000.
20 个问题 查看全部
Weird graphical issue stripes
I have a stripe going down the middle of my screen was hoping someone may know a fix i could do to solve the issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Yeah, I recognize this issue and it's not good.
Your GPU is probably dying and as it's hard (almost impossible) find the GPU chip, you probably do need to replace the motherboard to get this fixed.... Is it modded with a modchip? If yes, please remove this first to see if it's solved or not. Probably this won't solve it, so a motherboard replacement is required. Motherboards are also very hard to find.. So you can buy a donor-broken motherboard with other issues, so you can take the component of it. This is very hard and you do need solder experience.
Sorry for the bad news...
这个答案有帮助吗?
得分 1
4条评论:
That is fine I've got a donor I just wanted to see what the possible issue could be ill give that a go thank you :3
完成的
My pleasure! If you need anything else, please let us know :)! Good luck with the repair!
完成的
Well the only other question i'd have is are the other gpu chips interchangeable or do i need that models chip to replace it?
完成的
You do need the exact model unfortunately..
完成的
添加一条评论
添加你的答案
Kurono 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 79
