跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
iMac stopped working / PSU or Power button?
Before this problem i needed to wait some time, to power button start to work.
But now it stopped working, i waited, clicked many times, tried to plug out the cable, wait 10 seconds. and nothing worked
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@sobaken fist thing you want to check are the diagnostic LED's. The iMac (20-inch 2007) has four built-in diagnostic LEDs on the main logic board that can help you to troubleshoot the computer. The four LEDs are located to the right of the memory slot, under the hard drive data cable
Let us know what you find out about those LEDs and what they are showing you.
完成的
添加一条评论
1个答案
To find the on board diagnostic LED’s after removing the display bezel iMac Intel 20" EMC 2133 和 2210 外圈更换
Look into the cavity near the RAM slot assembly on the right you will find the 4 LED’s often covered with a small piece of black tape. Once you’ve removed the tape, plug the system in do any of the LED’s light?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Собакен 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 77
