跳转到主内容
加入维修社区 - 创建账户
Apple 20英寸 Intel iMac 的维修指南与支持。
Won't boot up
Circle with line through it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well that’s not a good sign, but a repairable one! Either the OS is missing or damaged on the drive or the drive its self is damaged and will need to be replaced.
As Apple produced a very versions of this model you’ll need to figure out which is yours 20” iMac listing
As an example review this guide on how to gain access to the drive iMac Intel 20" EMC 2105 和 2118 硬盘更换 it will give you the general idea what’s needed. Be careful as this series uses an older version of SATA interface so you will need a drive which supports the older version SATA II (3.0 Gbps) if the drives spec sheet doesn’t list this you’ll need to find another drive.
Now the tricky part! Hopefully you still have the CD’s/DVD’s that came with the system as you’ll need the OS installer disk to re-install the OS and depending on what your system is your options maybe limited as to the highest version you can run on your system.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Irene Villanueva 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 132
