MacBook Air M2 display not functioning after display replacement
The Macbook Air, on the latest MacOS 15.1 Beta, has gone through a display issue so I had to replace the display. I've worked on many apple devices as I run a repair shop, however in this case, when I replace the display, it functions as usual for about 5 mins and it completly goes black. Tried with a new display in my shop, same outcome. The Mac runs completly fine with the broken display, and when connected to the external screen.
4条评论
Where did you get the display?
由 DanJ 完成的
I've got one from amazon, and the second batch from ifixit.
由 Chanhyeong Kim (Chan) 完成的
To be clear the Amazon display was a factory fresh display and I believe that is also true with the iFixit display as well.
What happens when you boot up under iOS 14? Using Beta versions might change things which has happened before.
由 DanJ 完成的
Did a DFU restore to downgrade it to macOS 14, still the same outcome. Maybe apple updated the firmware to block third party repairs?
