跳转到主内容
FixHub Power Series | 便携式焊接站的维修和故障排除信息,便携式焊接站和智能烙铁的组合。2024 年 10 月发布。
What is the max temperature?
How high does the temperature go? Will this be hot enough to repair game console hdmi ports that require a big heat output? I’m also curious to know if y’all will be selling a portable hot air station as well.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
And , if and/or when you do produce a portable powered hot air machine, will it be compatible with this solder station, or will it be a entirely different station that will require a complete (forced) upgrade in order to have the solder station, soldering iron and hot air all be part of the same power supply/station? I realize making it not be compatible would be the same smack in the face, passive robbery that we have come to expect from Apple, and come to expect denouncing from iFixit… but, you know, even Apple was cool af once, so, how sure can we be that this won’t be ifixit’s fall to the Dark Side? It would have been so much better to just release the portable power station/ soldering station with a hot air rework station already a part of it, and then I could happily forgo any mention of the Sith… right?
完成的
Hi @thousandsunny, good point! I can't speak to plans around specific tools, but we are really optimistic about the FixHub Power Station with 100 Watts of USB Power Delivery output as a platform for future development.
完成的
添加一条评论
1个答案
已选择的解决方案
Yes, absolutely. The max temperature is 420C or about 790F. That's plenty hot enough to do the HDMI ports. They are still a tricky repair with a soldering iron (easier with a hot air station), but it can be done. We're working on some repair kits for exactly this repair!
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
James Cantu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 665
