跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Logic Board Failure due to Nvidia Graphics processor GT330M
Hi all,
I purchased my Macbook pro 1.5 years ago in Aug 2010 (did not purchase Apple care for extended warranty) . Started getting kernel panics recently and after every panic attack the machine would beep 3 times repeatedly. However, after not bothering with it for many hours (busy with work) I would be able to turn the machine on and use it for 5-15mins and would experience another kernel panic. I recently took it to Genius Bar in UK and was advised it was a 3rd party conflict (Sophos anti-virus) issue. I was advised to delete Sophos and everything would be fine. But it wasn't the case and I had to travel to go again. This time I was advised that the technicians would run a detailed diagnostic test and they suspected that it was a Logic Board or RAM issue. Today I was advised by a store personnel that it was a "Logic Board " fault and had to be replaced (costs approx 400GBP). I wanted the technical details of the fault emailed to me so I could get a second opinion. Instead, I get an email advising me that I have to physically go to the store to get the technical details of the fault.This is so disappointing. It has lasted just 1.5 years and as a student I just don't have the funds to get this fixed (could probably get a decent PC for that money).
On Monday the Apple store informed me it was my Logic Board. I wanted to find out the exact details of what's wrong with the Logic Board and waited to hear from them for two days. Initially they said that I could not get this by email. Yesterday when I rang them again, I was advised that they were running more tests to make sure it was the Logic Board.
Today I get a call advising me that their diagnostic test LO AND BEHOLD highlighted that their "GRAPHICS CARD" ( Nvidea ) had failed. When I pointed out the whole "NVIDEA-MACBOOK PRO SAGA" genius bar member ( she was nice and empathetic) said to me that the problem with my GRAPHICS CARD was not the same problem. So, I asked her to specify what the problem was with " my graphics card". Apparently, they do not have the techinical knowhow (even it went to their factory or some sort of centre) to find out what was wrong with the GPU and all they do is plug in a gadget to test it. This seems like a party line that they have to tow. All in all, I will have to fork out 400pounds to get this fixed.
However, I am not going to accept this and am going back to witness the diagnostic test. I would like to arm myself with as much info as possible about this whole NVIDEA saga. Spoke to Apple Centre and they were very helpful. However, the ultimate decision to put in a new Logic Board FoC depends on the store manager.
People with new Macbook pro's (Nvidia GT330M) and not just the old GeForce 8600M GT seem to experience this as well. Help and suggestions are much appreciated.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
11条评论
Have you read this? Or this? Might be a driver problem, not logic board at all.
完成的
Only way to fix Mac Book Pro 15 Mid 2010 by software is older
gfxCardStatus 1.8.1(download site: https://software.com/mac/apps/gfxcardsta... or whenever you find it)
don't try newer versions !!!! it will no work. Then install gfxCardStatus 1.8.1. in menu check mark: Intel Only. in preferences, check mark:Load gfx.. at startup. and. Restore last used mode at startup
It will never shutdown but it will never use nvidia graphic card
完成的
Folks, I have had the same issue and by doing an exhaustive research on this issue, I found what seems to be a viable solution. The problem seems to be the fact that the lead free solder is not as reliable as it once used to be. This affects the GPU over time as the solder points crack and don't fully sit properly. By reballing the GPU, I have had my 2010 macbook pro work like new after the same constant kernel panics and restarts.
Do a search on GPU reballing to find local services. I had to ship mine to Cali but got better than expected results.
完成的
Definitive solution here!
After trying a lot of different approaches to this problem I finally got a really good fix for this problem. In fact there's 2 good fixes. An easy software fix that you can find here: https://github.com/julian-poidevin/MBPMi...
And a hardware fix. Both of them are mentioned in this Thread: https://forums.macrumors.com/threads/gpu...
Good luck, everyone!
完成的
https://www.youtube.com/watch?v=sasfUgVG...
End everything will work. Sad Apple that You are doing it for Your clients, pushing them to buy new computer.......
完成的
显示更多的6条评论
添加一条评论
20个答案
已选择的解决方案
Save all documentation on this repair and watch for a new class action law suit. If there is one, you may be able to recover everything paid for this repair as were the users of the failed 8600 GPUs.
这个答案有帮助吗?
得分 8
4条评论:
The problem is not the GPU but in fact the CPU!! Update below:
I have some interesting news on this subject. I have read everything about "baking" and reflowing the GPU and also some repair shops that say the only reliable solution is to replace the GPU. But in a discussion with a reliable repair source I got this input from him. Seems tough luck for all of us with the problem!
"Unfortunately there is no repair that can fix this board. It is actually the CPU that fails. There are no new CPU’s availabel. Be careful if other people offer a repair as we know this board very well and carried out multiple tests. .....
Yes it is not very well understood. We repaired approx 40 of these and nearly all of them failed within the first year. We only like offering permanent repairs so withdrew the repair. It's the memory controller inside the Cpu that fails. The Cpu also carries out the graphic switching functions."
完成的
UPDATE 3/10/16
asle - The class action suit that did get filed and announce in Feb 2015 - https://www.apple.com/support/macbookpro...
Was short of the 2010 models and the 13" models and it was the GPU
完成的
Apple admitted this was a fault and there was a specific Quality Program for this 2010 model. https://support.apple.com/en-us/HT203554
Unfortunately this ended last summer, about the time my 2010 MBP 15" started to crash ;-(
完成的
@asle - %#*@ Apple for hiding these things and not making them more public. This is the first I have heard of it. The lawyers prolong settling so the window for repair is shortened and the customer gets it in the tukas. But if there was a law suit and a repair was made and paid for, Apple should have to cover the cost.
完成的
添加一条评论
最有帮助的答案
Here's the PROPER fix to this issue:
The issue with these laptops is not caused by the GT 330M GPU, but is instead the fault of a poly-tantalum capacitor near the CPU that supplies power to the GPU's frame buffer. Poly-tantalum capacitors are quite unreliable, and when this capacitor intermittently fails, the voltage to the GPU drops, and it causes a kernel panic. The thing is, heating the board in an oven or reflowing the GPU will temporarily fix this issue by indirectly heating the capacitor, as capacitors are known to sorta fix themselves when heated up.
Therefore, you can permanently fix this issue by replacing the affected capacitor, a 330µF 2.0V called "C9560" with another capacitor that isn't a tantalum one.
I recently fixed a laptop with this issue by replacing C9560, and it would die after 5 minutes of running Furmark. After replacing the capacitor, it has been running the same program for over 5 hours with no issues!
这个答案有帮助吗?
得分 22
33条评论:
Absolutely correct! I replaced the bad capacitor over the 2016 Christmas holidays. I replaced the bad capacitor with a Aluminum Polymer cap (Louis Rossmann video on replacing the cap: https://youtu.be/DzcgT_fiVTA ... ignore some of the language used!). Since I had the logic board out, I also cleaned out the thermal paste mess that Apple created. I used some Arctic Silver 5 and got everything working again.
Result ... no GPU panic! The solution is a permanent fix ... Without this fix, you are stuck using the internal display and Intel graphics processor. If you need to use an external display, this is the only way to go! Anytime you connect a external display, the dGPU is used. Additionally, wake-up from sleep was quicker! Everything just works a lot better ... like it did back when I got the laptop.
My Setup: Macbookpro6,2; MacOS 10.12.2; 8GB; 512 GB SSD; External display - Dell U2713HM;
完成的
Yes! I should credit Louis/Duke for the information, as I would have had no idea that this was actually the issue myself haha.
完成的
where did you buy the proper capacitor
完成的
I pulled it off another broken donor board, any SMD capacitor with the same or similar specifications as C9560 that isn't a tantalum should work. Mouser.com will probably sell something that works. The only thing is that the new capacitor will likely not have the same dimensions, so you may have to scrape the trace or make a new pad to solder the new one in.
完成的
I got my replacement caps at digikey.ca ... they have a US site as well. Here is the replacement part link:
CAP ALUM POLY 330UF 20% 2.5V SMD (https://www.digikey.ca/product-deta...co...)
完成的
显示更多的28条评论
添加一条评论
Kernel Panics are often corrupted memory blocks caused by a misbehaving process. While it's possible the cause could be bad hardware (RAM or the GPU) I've seen more software causes than hardware failures.
Did you upgrade your OS or add/upgrade any applications just before you started seeing the kernel panics? There have been reports of some video driver problems during the Lion upgrade process that cause odd kernel panics.
I would first try isolating out the software causes. The easiest is by using an external HD (Firewire would be better than USB here) which has a fresh copy of Mac OS-X 10.6.8 on it (not Lion 10.7.x if that is what you had been using). Then select it as your boot disk (you can still use the internal HD's apps). Did the problem go away? If that did make a difference you'll need to make a full backup of your HD wipe it down completely then using an external HD to boot from install a fresh copy of OS on the internal and use the migration tool to copy back your files.
One note here: if you did upgrade to Lion you want to boot under a straight Lion OS external HD not one had was upgraded or copied from an upgraded Leopard or Snow Leopard OS (to make sure you don't copy over any of the older drivers). To prep and install the fresh copy of OS.
If the panics are still happening after booting up under the external HD you could try exchanging out the RAM with a fresh set of SIMM's. I wouldn't spend the effort moving your current SIMMS from slot to slot or removing one, unless you upgraded the RAM after you bought your system (different manufactures). Otherwise I suspect one of your Apps has an issue, remember what apps you use and the order you use them after a fresh reboot to see what apps could be suspect then focus on making sure you upgrade these to the newest versions (don't forget OS add-ons and virus checkers).
As far as the Nvidia issues of the older MB Pro's ('08) Nvidia had a bad run of chips do to a design flaw. Depending on where your chip was located on the wafer the thickness of the layers are very slightly different. The inner core are thicker and the outer edge are thinner (think how centrifugal force works). The current theory is the dies (chips) closer to the edge just couldn't hold up as well under stress as the others. Normally these outer edge chips get tested more fully and depending on what happens they are tossed out. Some how the process failed so some got released. As far as I know only the 8600M GT was effected. As your system has the 330M GT it does not relate as being the same problem.
Check this out about the older Nvidia 8600 GT chip: http://www.macrumors.com/2008/10/10/some...
Bottom line here is your issue might be a new issue with the 330M GT chip which so far has not been acknowledged by Apple or Nvidia. So far no other system manufacture has had issues with this chip either as far as I can find.
References:
http://www.notebookcheck.net/NVIDIA-GeFo...
这个答案有帮助吗?
得分 5
1条评论:
Just got back from the Apple Store today with a system that had been repaired before just over a year ago for the Nvidia problem still again. This time had to pay out $40 bucks to cover the labor but at least they paid for the part. So don't give up!
完成的
添加一条评论
All of you are wrong, the problem and resolution is here:
https://www.youtube.com/watch?v=DzcgT_fi...
这个答案有帮助吗?
得分 4
1条评论:
More on this fix above, under 'Sam Freeman'.
完成的
添加一条评论
You're going to love this...
It is very probable that issues with panicky GT 330M's isn't actually a problem with the GPU as many have thought.
According to this amazing thread on MacRumors:
"Apple made the same mistake they made with the 820-2610 and 820-2330 where they ran out of space on the motherboard for C7771 so they made it a tantalum one. This is not suitable for a rail that is always on, as C7771 is for an S5 rail - so it dies. Voltage fluctuates, and eventually the machine stops turning on. On the 820-2850, that same 330uf tantalum capacitor re-appears on the framebuffer power supply for the GPU and the VRAM.''
One possible fix is to replace the dodgy cap with a regular type, however in the mentioned thread you'll find a soft workaround, which involves patching the Info.plist of AppleGraphicsPowerManagement.kext.
And the best bit....
I got my GPU Back!!
这个答案有帮助吗?
得分 4
添加一条评论
I had the same desease for a long time.
The bug is hardware : it's due to a bad type choice on a decoupling capacitor used on GPU motherboard part
But good news, you don't have to replace the motherboard
Julian Poidevin sent me this:
Hi, I created a software to automatically correct this issue, you can download it on github, it's free :
Install it. Password requested is your login session password because that software must change SIP (System Integrity Protection) to force GPU to take medium speed always. For more info read FAQ in poidevin site.
Now my MBP 15 mid2010 is working fine
If you have installed GFxCardStatus let it in dynamic mode.
Any time you update MacOs you must do a reinstallation of the poidevin fix again.
That fix was developed based on fabioroberto investigation
see post #20
这个答案有帮助吗?
得分 3
1条评论:
Thanks for advertising my app :-)
完成的
添加一条评论
kernal panic always come due to Ram. took out the 1 ram from the laptop and run the laptop. check kernal panic is coming or not . if coming then remove that one and put back the old one. if still same problem then reinstall the mac means first back up all your data the reinstall the mac with restore dvds or retail dvd. it will solve you problem. i have a same mac core i5 mid 2010 15 inch. i already faced this problem of kernal panic . this was solved by changing 1 ram . i m happy becoz my mac is covered with apple protection plan. try this will help you
这个答案有帮助吗?
得分 1
7条评论:
Kernel panics are NOT always caused by RAM.
完成的
i know but i faced 3 times this only caused by ram only ... and one time error recover by only reinstalling mac
完成的
sim - you might want to change this to " kernel panics can be caused by:", rather than "always come".
完成的
I had the same problem and it was not the GPU itself neither RAM or software issue. The tantalum capacitors are ALWAYS fragiles. By replacing C9560 (330uF 2V) on the mother board, the problem was solved. Cost : 50cts!
完成的
@Axel I think you have to put in some more info about what and where (pictures?) because this was a complete mystery to me. Never heard of this solution.
完成的
显示更多的2条评论
添加一条评论
remember the sale of good act gives up to 6 years protection...
http://conversation.which.co.uk/technolo...
这个答案有帮助吗?
得分 1
添加一条评论
Dude, this has been a pain in my particular side for a couple of years. I am an old Systems Integrator in the US back when it was all bleeding edge technology and there were no schools to certified you (actually, Apple did have us certified at both personal tech levels and then my company being Apple authorized) because we were the ones figuring it out between the Mac/Apple OS, DOS & eventual every variation of windows fun plus the different flavors of Unix. My world was integrated them all together when "that can't be done!" Bah Ha Ha, watch me. Anyway, all I'm saying is I know enough about all of these to be dangerous. The thing is, there are enough similar where you know what to look for when diagnosing issues and at the very least, ruling out WHAT IS NOT WRONG. With the new Apple OS's, my knowledge of UNIX has been very helpful.
Now, my !&&* with my MacBook Pro. During its warranty period, no problems of course. Then I started having the bizarre issues of it scrambling the screen and unable to get it to a startup screen or even a prompt thru safe mode or verbose. I was essentially retired so I no longer had my usual contacts in the industry as I had also relocated. I did my usual due diligence to rule out what was NOT the problem and being a little lazy, decided to take it to the local "Apple Store" along with the list of what was not the problem AND the info on the known issue with the logic board and their double secret probation recall program.
Now, I understand how leary places as this do not like to be told what joe blow thinks is wrong and especially when it's a woman. I gave them a copy of the recall issue and they essentially scoffed. It took them over a week to finally reach the same conclusion I did and they ordered the logic board that took longer than it should have based on my knowledge of how well Apple does with turn around when they know it's a known issue - they kick butt to get you back up and running. After the amount of time it took them to diagnose the issue and how they did it gave me my first thought of "hmmm, this feels wrong". After the amount of time it took to get the replacement, it really made me wonder if I shot myself in the foot by just bringing it in to this store before calling Apple direct. When I got the exorbitant bill and the non technical cashier conveniently couldn't locate a service ticket detailing the Service call and all that was done set off my bullshit meter plus the numerous smacks to my own head for following the route I took. I realized I had let a store that goes out of their way to look so official that they were actually not an authorized service center. I still do not know where they got the replacement board. I originally chalked this up to my laziness and stupidity for knowing better and letting this happen but it worked and I just let the episode fester in my head.
Then, a year later, after the "double secret probation recall" had expired, I started having a similar issue. Again, I went thru many gyrations of ruling out every possible problem that left it with an obvious video board issue which was also being recalled in my model. I called Apple support this time and after listing all I did and the results, they agreed and after I told them of the local store that was not authorized and I was unwilling to go 90 miles to another, they gladly set up the shipping swap. EXTREMELY helpful and based on having used this same processed years earlier on a warrantied different macbook mother board failure, I knew this was the way to go and again kicked myself for my mistake the year before. They had me a shipping box the NEXT day and had it not been a holiday weekend, I'd probably have it back today. There is still the Murphy's law chance that it started working for them or it gets lost in transit or that I jinxed the whole process, but I'm feeling pretty confident I'll get a happy laptop back in a day or so and a refund of the "deposit" I put down since it is out of warranty.
Once this is done, I do hope I can find out a way to have Apple look into this store I used and their actions. I have resigned myself to the fact that I will probably never get any $ back from my stupidity of not calling Apple first and they could have given me the heads up that they did not see this location as one of their blessed stores - but at the very least, I hope they can look into them and make them make sure to inform future customers they are not working with APPLE. Shame on them and shame on me because I, more than the average bear, should have known better!!
这个答案有帮助吗?
得分 1
2条评论:
I'm sorry you had a rough time with the servicer. Apple does authorize repair centers and they are limited on how they can mark their establishment. If they follow the Apple Store layout and don't clearly mark they are not Apple you have a case! Speak with your local consumer law center. Apple was rebating people the moneys they paid-out if they paid a authorized service center. Don't wait to long here as the time is against you.
完成的
Naming & shaming of place please. Not mentioning name makes this a very long, albeit useless rant, since someone else will surely go there and get scammed!
完成的
添加一条评论
I tried Gfxcardstatus version 2.0.1, it resolved my GPU issue on my Macbook mid 2010.
after running the app, choose Integrated only.
I recommend the usage of this old version 2.0.1 instead of the last version, it works perfectly on OS El Capitan - Mac mid 2010.
这个答案有帮助吗?
得分 1
添加一条评论
I 've never heard of this quality program, too bad cuz my MBP has stated to kernel panic since the release of Mavericks (before it was stable on snow leopard).
Now i have found a remedy for this problem is to install the gfxcardstatus, mine is version 1.8.1, and for Sierra you need another version, this software forces your mac to use the integrated intel graphic card and not the Nvidia which causes the panic, so when the software is installed you have to select intel graphic card only in preferences. Another solution is to change the tantalum capacitor that is the real cause of the problem. I haven't done this cuz i don't have the tools, but the gfxcardstatus works fine for me. I have also noticed that google chrome is causing the panic, so use safari of firefox instead along with gfxcard status
这个答案有帮助吗?
得分 1
2条评论:
In fact google chrome (or other app) can cause the panic because they use hardware acceleration therefore they use the Nvidia card to make the browser faster, and this will overwrite the gfxcardstatus even if integrated gpu is selected, however if you want to use chrome (or other app that used the gpu acceleration) go to preferences and uncheck "Use hardware acceleration when available", i believe you can find it at advanced settings in chrome. Do the same if you are using firefox. This worked well for me
完成的
Another solution is to downgrade to snow leopard, which is more stable OS and will not cause the gpu panic. If you choose this solution you don't have to install the gfx software and you will not encounter kernel panic (at least this happened to me among many others). Of course this solution is not the best because snow leopard is not supported anymore and many new software won't work for this OS.
完成的
添加一条评论
Had the same problem--apple genius, after video test, reported GPU failed, replace logic board. They offered a replacement logic board for $310 (including two way overnite shipping and labor). Told me that free fixes ended 12/2013. I had the fix done and I'm hoping for reimbursement either via executive letter or class action. Now I'm looking for a torture test for the Nvidia 330M gpu.
这个答案有帮助吗?
得分 0
添加一条评论
Worked for me. I baked for 10 minutes at 385 degrees F. Make sure that there is plenty of silver compound between the heat syncs and the processors, as my fans initially ramped way up and a hardware test ("D" key upon startup with install disk 1 inserted) identified a system error related to the temp sensor failure. After removing the previously baked motherboard a second time, adding silver compound to each of the three heat syncs, and reinstalling e motherboard, then the three processors made better contact and the issue was solved. My Mac has never been as fast as it is now! Simply incredible!
这个答案有帮助吗?
得分 0
6条评论:
Hi Matt, I'm not new to fixing my own computers, but I do it by researching a lot and trying different recommended fixes. I have a macbook pro (A1286 model) with the video card failure. Took it to an "expert" and because his work load it took him more than a year to answer me what I already knew I than a new logic board was needed, so I took back.
Well, my question is what do you mean by "baked for 10 minutes at 385 degrees F"? Is it a process in an special machine (oven)? Please help me, I'm not interested in investing in another "professional" and I'm considering the last option to sale the machine in parts so at least I can recover some of the money invested. Thanks in advance for your reply.
完成的
mizqhc - Matt was talking about baking in a normal stove oven. I will caution you while some have has limited success, others found it didn't help at all. Of the few cases listed here worked and then within a month or two the system died again. The problem here is thou aren't really fixing things just band-aiding it. At this point there is little to loose so go for it.
完成的
My MacBook Pro 2.6 Ghz 17" works better than ever. Yes, I wrapped the majority of the logic board in tin foil, but left the processors exposed. I then placed it in the oven in my standard kitchen.
The process reflowed the processors and the video chip. It worked perfectly for me and my Mac is faster than ever, but I have read that it didn't work for other. I can say that the "blanket" method did not work. I would certainly give it a try before scrapping your Mac for parts. Just make sure to follow the iFixit video and remove any plastic bits that may melt - the use of tin foil will protect any other plastic parts that are permanently fastened to the board.
One thing to remember, make sure to either save some silver paste to place between each processors and the heat sinks OR buy some silver paste on Amazon (or the internet) and place droplets on the heat sinks. This will allow for the Mac to properly sense the temp of each chip and the video card.
Good luck!
完成的
I will try it in the coming days, when I do I will let you know if it worked it or if I cooked it. Thanks Matt and Dan... =D
完成的
Hi @mizqhc - did you do the baking thing and did it work?
完成的
显示更多的1条评论
添加一条评论
gfxcardstatus has been my answer - allows you to manually force the integrated or discrete graphics. Free software - download and try it. Once installed, I stopped having kernel panics. You will also want to go to system preferences, energy saver and turn off automatic graphics switching.
这个答案有帮助吗?
得分 0
2条评论:
This only works on dual graphic based systems which has an internal Intel HD graphics engine in the CPU & a discrete GPU. Make sure to check your systems specs. You may want to also see if your system is covered under this extended warranty program: MacBook Pro Repair Extension Program for Video Issues.
完成的
I used GFXcardstatus 2.0.1 and it solved my problem. I even forced it into discrete mode and it seems to work fine. I don't think it likes switching back and forth between integrated and discrete modes.
完成的
添加一条评论
i have MBP mid 2010 330m , i remove the internal fan and use external fan,it won't crash anymore, i think the fan Interference the signal in vram that should fix for now : )
这个答案有帮助吗?
得分 0
2条评论:
How did you do that? What kind of external fan could be used and how can be fixed to MBP body? I would like to know it step by step if you are kind. Thank you in advance
完成的
it not fixed to MBP body you have to take the fan out.so it will not move to anywhere you have to use like desktop. but it will fix and rarely crash . you can read my topic here
Problem with NVIDIA GeForce GT 330M 256 MB?
it the best way to fix my MBP for now i know it weird but it work very well i use this set up for a 6 month now and it very rarely crash
完成的
添加一条评论
How to fix->
It start failed in my computer after Update to el capitan but rarely but after update to Sierra restart every time. Just use gfxcardstatus and choose intel only and whoala not restart anymore. Cannot use the switch must choose one intel or nvidia
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
Does anyone had this issue but didn't solved it with GFXcardstatus 2.0.1?
这个答案有帮助吗?
得分 0
2条评论:
Hi Jurgen ...
If your MBP is a MacBookPro6,2 ... and experiencing GPU Panics ... Yup! Have a look here: Problem with NVIDIA GeForce GT 330M 256 MB?
完成的
Yes!!!
See my post below (answer389413)
完成的
添加一条评论
I decided to approach my Macbook 15" 2010 kernel panic issue from a hardware standpoint by replacing a faulty capacitor which resolved the problem, although a lot of people have successfully fixed it through software.
这个答案有帮助吗?
得分 0
添加一条评论
FYI this issue is only present in the 15” models. The 17” 2010 i5 and i7, are not affected (Mine has been working fine for the past 8 years).
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem with a mid 2007 macbook pro running under Mavericks, i played some music on it on a friday noon, i went to the gim for about 1 hour, i did put the macbook pro in sleep modus, and when i got back from the gim and when i opened the lid of my computer, it wouldnt wake up anymore, i removed the power cord and battery, i tried to reboot this macbook pro, nothing, just a boing, and my screen stayed black, i tried everything, booted it up with the ram removed, only powercord, only battery, harddrive disconnected, and when i searched the web with my iphone, i realised it whas the GPU that failed, an Nvidia chip, i disassembled the complete macbook and i did a logic board reflow in the oven ad 200 degrees celcius for about 7.30 minutes, hoping and praying offcourse, and when i putted it back together . . . It jus booted up like nothing happened . . . Crazy, why is this happening to computers that costs SO much money? I have an old pc, with a Nvidia chip also and i had NEVER the kind of problem i had with my old macbook, now i am using a 17 inch macbook pro with a dual Nvidia chip and i am just scared that it would happen again over time so my fans are blowing ad full speed all the time, i clean out the dust once a month and i have a temp monitoring app and cpu activity monitor installed now . . . I hope that this macbook doesnt die on me . . .
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
DBcell 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 38
过去 30 天: 266
总计 142,247
