跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 个问题 查看全部
iMac suddenly running slowly.
Model Name: iMac
Model Identifier: iMac7,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Suddenly very slow when browsing. ISP checked connection and it's fine. Did the disk/permissions repair stuff. Still slow. Mac version 10.5.8 - software updated.
How do I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Apple iMac "Core 2 Duo" 2.4 20-Inch (Al) Specs
Identifiers: Mid-2007 - MA877LL - iMac7,1 - A1224 - 2133
完成的
What type of Internet connection do you have to the internet? Cell modem (wireless), Cable, DSL or Fiber. The first two of these are shared connections with others around you, the others are dedicated connections between you and the ISP. In shared connections you may encounter time points your access will be slow, choppy or even fail. Try being the odd man out connecting when others are not likely using the connection. Also you may have other devices in your home that are sapping your allotted bandwidth or even neighbors if you have an open WiFi AP.
完成的
添加一条评论
2个答案
已选择的解决方案
Try seeeing just what your ISP speed is, it doesn't matter who your carrier is: http://www.att.com/speedtest/
If you are using the airport, try switching to a hardwired ethernet connection to rule out an Airport card issue. If the problem persists, call your ISP and they will "painfully" walk you through everything to check. They can also reset your modem and test your lines. Most of the time when I have a slow down, it's not me but them but they make you do every check before they do anything.
这个答案有帮助吗?
得分 3
添加一条评论
All Macs begin to slow down with age — MacBook Pro, iMac. It doesn’t matter. I've listed some of the reasons below that may cause the Mac to slow down and found several ways to make your Mac faster. You can try.
1. Clean up your hard drive
2. Update your macOS.
3. Manage your Startup Items
4. End processes with Activity Monitor
5. Upgrade your hardware
6. Use the Mac cleanup software. Such as Mac Cleaner of iMyMac
7. Plow through your desktop items and Clean the desktop
8. Remove extensions to make your Mac run faster
9. Clean lots of outdated cache files
10. Finder uses too much memory and Adjust Finder preferences
11.Animations and rich graphics are extremely resource-hungry. So cut down on animations
12. Reset SMC to factory settings
13. Too much temporary files in memory. So restart your Mac regularly
14. Turn off the FileVault encryption
15.Over time, permission problems occur, causing your Mac OS X to lag, freeze and even crash. Then You can repair disk permissions.
16. Clean up Downloads and Trash folders
17. Clean up Preference Panes
I hope the above method can help you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
steve lowe 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 1,492
