跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Audio doesn't work properly
Hi, my 3ds sometimes has no sound and other times it seems like I'm hearing a radio. I tried to use headphones but it doesn't give any problem. What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
When the headphone jack is working, it’s probably speaker related!
But before I can confirm that, I need to hear an audio fragment about this. Can you share a video/audio fragment?
Thanks in advance!
这个答案有帮助吗?
得分 2
6条评论:
Good morning, sure!
At the beginning of my MP3 audio the 3DS was turning on. Despite the audio switch being off, the speakers were making a radio noise. After this, the 3DS played the audio of some games, but I could still hear the radio effect. I created some audio fragments, but I deleted them because the 3DS didn’t reproduce any audio.
https://drive.google.com/file/d/1xKIohz6...
LDR
完成的
Hi!
It’s either the speakers OR the audio processor! I recommend to replace the speakers first, as this is way easier. Can you let us know if that fixed it? Thanks!
完成的
Where I can find the audio chip on the 3ds? I searched it on google but i didn't find anything useful. Anyway I will try replace the speakers and I'll let you know. Thank you
完成的
Yeah, it’s difficult to find this one! Best thing to buy a broken (donor) motherboard, where you can take the audio IC from! Best thing is to replace the stereo speaker assembly. Fortunately it’s a complete cable with the speakers already soldered on! So no soldering is required to replace it! Usually replacing this is the fix! Please let us know how it goes!
完成的
Good afternoon, unfortunately I didn't repair the 3ds because the owner decided to not continue the fix for now. I wanted to thank you again for your availability and if I have some news I'll let you know. Luca
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Luca Di Renzo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 33
总计 199
