跳转到主内容
加入维修社区 - 创建账户
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
My 3ds won't turn on after charging even after battery replacement
I recently found my old 3ds xl and I tried turning it on to see if I could relive some memories, to my surprise it didn't turn on so I plugged it in to charge for about 4 hours then tried again and it didn't power on, I then tried turning it on whilst it being on charge and it worked but as soon as I unplug it turns off. I ordered a new battery and replaced it, then it was the same problem I don't know if the motherboard is the issue or the battery. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Vince!
So the 3DS does turn on when it’s in the charger right?? It’s probably the battery which need to be replaced!
Best thing to do is to buy a new one and try it!
Please let us know if this fixed it or not!
这个答案有帮助吗?
得分 1
2条评论:
I have bought a replacement battery and no it did not work, I then tried another battery and that did not work either. I'm lost and don't know what to do anymore
完成的
Then it is something on the motherboard! Please check the fuses, labeled with “F” on the motherboard. Also check for damage and clean it as well with isopropyl alcohol!
完成的
添加一条评论
添加你的答案
Vince Apostol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 272
