跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Ps3 blue ray drive problems
Ok so I had a ps3 fat cechopo1 and it worked fine before but after I took apart and put it back together my blue ray disc drive no longer took any disc a blue light appeared on the ps3 and when I tried to push the disc it the mechanism did not pull it in nor push it back out what is the reason for that I tried to replace the blue ray drive multiple times but the results where always the same
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Carmine!
Could be a lot of things to be honest!
Please check the PS3 drive - motherboard ribbon cable (you can test the cable by doing a continuity test on both ends, if it beeps, it’s OK).
Also check the drive it’s power cable.
This issue is common and it could be the drive it’s mechanism which is broken.
I saw this issue sometimes and replacing the drive for another one does work. Make sure to transfer the old drive it’s PCB to the new drive!
If this didn’t solved it, then it’s most likely something on the motherboard (transistor, or something else)…
Please let us know your findings! Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carmine Varrone 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 40
总计 439
