LT won't work after replacing the analog sticks.
Hi. I just replaced both analog sticks, I had actually done it before. But this time after replacing, the LT appears to be pressed down. It's not the sensor sense I tried to switch them and the sensor works on the RT. So it's not the sensor, I don't know if it could be a trace that got damage or something. But not having schematics available is complicated. Does anybody have any advice or suggestion?
The best thing to do now, is to take the motherboard out and make some pictures. Maybe we can see if something is damaged or not.
由 koppie007 完成的
I'll do that. Thank you
由 ENOC ZELEDON 完成的
My pleasure and thank you!
由 koppie007 完成的
Ok. Im uploading the pics. But before hand what I'm gonna say. U.might see that I did a fix to one of the traces that connects the sensor. What happened was that after reconnecting over and over the sensor, suddenly that trace ripped, but it's fixed, there's continuity.. and I had the issue way before that happened to the trace. . As I had said it happened after replacing the sticks.
[image|3395930][image|3395931][image|3395935][image|3395927][image|3395929][image|3395937][image|3395936][image|3395928][image|3395934][image|3395932][image|3395933]
由 ENOC ZELEDON 完成的
