跳转到主内容
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
Wireless controller doesnt work when im in a PS4 party
So, let me explain this wonderful problem for you guys.
When i am not in a party, my controller works perfectly, wireless or not.
BUT, when i am in a party, i need to use it with the usb cable. If i try to use it wireless, eventually it becomes impossible. It gets really slower, my inputs dont work, and i need to bring the cable back.
I've tried to reset the controller, but it doesnt work.
Also, i've tested another controller, newer, stronger, beautier, but the problem persist.
Does somebody have any idea abou how to fix it?
PT-BR version
Deixe-me explicar esse problema incrível.
Quando eu não estou em uma party do PS4, meu controle funciona perfeitamente.
MAS, quando eu estou em um party, eu sou preciso usar o controle com cabo. Se eu tento usar sem o cabo, eventualmente se torna impossível. Ele fica lento, meus comando não funcionam, e eu preciso pegar o cabo de volta.
Eu tentei resetar o controle, mas não ajudou.
Eu também testei outro controle, mais novo, mas o problema persiste.
Alguém tem alguma ideia de como consertar?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi Luiz!
Could you make a video for us to explain when it's is happening? Are the controllers like 100% genuine? Are you using the original PS4 controllers from Sony?
完成的
@dan0 It's kind of difficult to make a video because the problem happens randomly from time to time. I can describe the problem as a really heavy input lag, which makes it impossible to play for a few minutes.
Yes, both controls are original from Sony, one of which is the one that came in the box with the PlayStation.
完成的
Answered you at the moment!
完成的
添加一条评论
1个答案
最有帮助的答案
Hi Luiz!
Alright, it could be the antenna which need to be replaced!
I would try this one first and see how it goes!
If this didn't fixed it, then probably the bluetooth chip need to be replaced. This one is difficult.
Guide: https://www.youtube.com/watch?v=VQmDlqj5...
Good luck with the repair!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Luiz Rodrigues 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 73
