power supply board replacement part
i'd like to get a power supply board (flextronics) for my 27" thunderbolt display. are these for sale? are they same is what is in a 27" iMac?
This should still be under warranty. If it is, I would certainly get the extended AppleCare warranty.
这个答案有帮助吗?
Hi
Power supply board part numbers are: 661-6048, 661-5543. I found boards available for sale on ebay and maybe available for other apple spares suppliers if you search using the part numbers.
这个答案有帮助吗?
Will both power supply board with the different part numbers be compatible for a Thunderbolt Display?
The question is still open, are those part numbers interchangeable or: what's the difference?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 6,651
7条评论
Hi aaronoehlke. Did you find the power supply board for sale?
由 SW 完成的
I also need this - it makes a weird noise - and it is coming from the power supply...
由 Antonkjaer 完成的
Have you got the power supply?
由 Karsten Bundgaard 完成的
Hi Karsten,
Nope - have you got one in Denmark?
由 Antonkjaer 完成的
Unfortunatly not!
显示更多的2条评论
