跳转到主内容
问题已关闭
Looking for Display Data Cable
Does anybody know where I can buy MacBook Pro 13 Unibody parts?
I had a little accident and poured redbull on my MacBook..after cleaning it the MacBook starts, everything works except the screen, its black. I checked on the Display Data Cable and I can see its broken. Maybe it was a friend when he tried to fix it. The connector of the cable is damaged, the one that is attached to the logic-board.
Where can I buy this product? Im a total Newbie to Mac, please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
Even if the LVDS cable is damaged you should get a gray screen cause the backlight (screen lightning circuitry) should work. Before buying parts I would connect the MBP to an external monitor then check if the video is normal on the external.
这个答案有帮助吗?
得分 4
2条评论:
I concur -- in fact suggested it because of the redbull spill. Ralph
完成的
完成的
添加一条评论
Apple decided that the internals of the Unibody displays are non-serviceable, so the display cables are a bit hard to come by. Your best best is to check eBay for the part or for a display with shattered glass for cheap from which to scavenge the cable.
这个答案有帮助吗?
得分 3
2条评论:
Hi
Is it possible to get the cable of any Mac Laptop Screen or do I have to get it of a MacBook Pro 13 Unibody ?? thanks for help.
完成的
Unfortunately, the cables are pretty exclusive between machines. You would need one specifically from a MBP 13" Unibody. Good luck!
完成的
添加一条评论
If the cable itself was the problem you would be in better shape. If I understand you correctly the connector on the logic board is broken. That being the case you probably need a new logic board. You can try using a external monitor and if that works you could still use the MacBook as a desktop computer.
However if the cable itself is bad that can be replaced for a lot less money. Ralph
这个答案有帮助吗?
得分 1
4条评论:
I have searched for a source for the cable without luck. Please confirm the cable and not the board is what you need and I'll keep looking. Ralph
完成的
thanks a lot for this quick answer
thats probably my poor english, only the cable is broken, not the board. however, I couldnt find where I can buy this.
完成的
The only cable I can find are part of a complete display--if anyone has a source for just the cable please chime in. Ralph
完成的
完成的
添加一条评论
Does anyone know the Apple part number for the display cable?
这个答案有帮助吗?
得分 0
1条评论:
duplicate question
完成的
添加一条评论
http://www.ebay.com.au/itm/Apple-A1278-1...
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,667
