跳转到主内容
加入维修社区 - 创建账户
Oppo 公司生产的手机的维修指南和支持。
Volume button is not working
On a picnic spot I used my phone to click photos.my phone is oppo reno 6 pro. It's a water resistance phone. Minimul water went in mobile . A button to do volume high is not working. How to fix it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Oppo reno 6 pro
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @tarunsoni77972
Being water resistant doesn't mean that it is waterproof. The phone will have to be opened and inspected as to what damage has occurred to the phone's internal components.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a teardown video that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tarun soni 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 12
过去 30 天: 15
总计 128
