跳转到主内容
The Dell OptiPlex 745 small form factor is a compact desktop computer that has been a work office favorite, and still sits at desks to this day.
Why is my CD drive not opening?
When I press the CD drive button it does not open what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@rufiniqbal what have you checked? Do you have power to the optical drive (CD drive)?
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @rufiniqbal
Check if the cd drive tray opens if you click on the eject setting for the drive in Win Explorer.
Go to Win Explorer (press the Win key + e key - both together) > This PC > right click on the CD drive icon > eject.
It it opens OK, then the eject button on the drive may be faulty.
If it doesn't open, then there may be a problem with the tray motor or the drive electronics and further testing would be required to find the problem.
这个答案有帮助吗?
得分 1
添加一条评论
You can try to force restart the computer
if that does not work, if there is a small manual opening hole in the drive door you can put a sim ejector tool into that to manually open it.
Or just stick a jimmy tool and pry until you can pull it out with your fingers
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rufin Iqbal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 52
