跳转到主内容
加入维修社区 - 创建账户
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
Internal monitor Show double image
A friend of mine have this Powerbook G4 A1052 1.33.
The internal monitor now works only at 640x480 and 800x600, OS recognise it as "VGA Monitor", and the screen is "doubled", as you can see on the following image:
http://www.flickr.com/photos/77200474@N0...
On the external monitor everything works well.
I've already tried reset nvram, pram, etc (also via open firmware at boot), nothing changes. It's the monitor that needs to be changed?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Try starting up in Safe Mode by holding down the Shift key on startup. If this solves the problem, remove the last thing you downloaded and installed.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Antonio Meloni 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 513
