跳转到主内容
加入维修社区 - 创建账户
Why my iBook won't power on from battery?
Hi all, am hoping you can help me with my dilemma here. I bought an iBook off of eBay a couple of years ago and battery doesn't hold charge. The adapter light turns from orange to green then back to orange erratically. Battery icon showed either 'X' or 0%. I replaced the DC inboard because the adapter pin got stuck in there. It works perfectly when plugged in (apart from erratic battery behaviour). I have just bought a new battery hoping it would solve my problem. But here's the thing:
1. When I plugged in the AC adapter, it turns orange the whole time it's stuck in but it doesn't charge the battery.
2. Battery stays at 29% and I got two lights on the battery indicator.
3. Coconut battery says I have 29% as well but it tells me that battery is not charging.
3. System Profiler also says battery is connected but doesn't show as charging.
4. I left the laptop on sleep and hoping it would charge overnight but nothing happened the next day. It is still 29%
5. I tried to turn laptop on without the AC adapter, but it won't turn on, not even a blink.
6. I have reset PRAM, NVRAM and PMU to no avail.
Are these signs of bad logic board? Thanks guys!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
sorry guys, forgot to add.. It is iBook G4 1.42 ghz OS X 10.4.11
完成的
Did you get the DC-IN board off eBay too?
完成的
Hi Mayer, yes I did. Do you reckon it's a dud?
完成的
添加一条评论
1个答案
已选择的解决方案
The first thing I would do is replace the DC_IN board from a suppliers with a good reputation. Who knows what you got off of eBay (the part probably came off a non-working machine and they had no way to test the parts).
这个答案有帮助吗?
得分 4
1条评论:
Thnks Mayer. I think you're right, I might need to do as you suggested. Though i dreaded the thoughts of having to open my iBook the 2nd time.. Didn't enjoy doing it the first time.
完成的
添加一条评论
添加你的答案
kusuma83 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 782
