跳转到主内容
Is the Wireless Network Adaptor replaceable?
I have an ACER Swift X laptop (N20C12) . The Wireless Network Adapter was working intermittently and now will not see my wireless connections. I have reset the router and all my other devices are working and connecting. Can the Wireless Network Adapter be replaced? Is it on the motherboard? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
معمولاً با ریست کردن قطعه مورد نظر در تنظیمات ویندوز این مشکل حل میشود ، در مرحله دوم نصب مجدد درایور قطعه می‌باشد.
در صورت عدم کارکرد صحیح دستگاه ، از یک آدابتور اکسترنال استفاده کنید
完成的
添加一条评论
1个答案
最有帮助的答案
Yes the wireless Network adapter can be replaced.
Click here.
This is for the battery but shows you how to open the case and remove the battery. Never do any interior work without disconnecting the battery.
Go to Step 4 and the Adapter is right in the centre of the photo.
But first of all does it appear in Device Manager ? Is yes then right click delete it and then open "Action" menu selecting "Scan for hardware changes" and Windows will reinstall the driver.
Does it work now. Yes or no? If no replace the adapter.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 84
