跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
MacBook Pro Keyboard and Trackpad Not Working
After changing the battery, the Keyboard and Trackpad stopped working just the power was working, after some research, I went and bought a new cable connector. After installation I just have the power working and CAPS is green. Resetting NVRAM and SMC didn't help Any suggestions I greatly appreciate it.
Update (07/17/24)
@danj
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Can you narrow down your exact model as Apple made quite a few different versions of this series. Take a look here for help EveryMac
完成的
@danj It's a 2015 Macbook Pro 13" A1502
完成的
添加一条评论
1个答案
This series has two cable connections on the logic board, one for the trackpad and a second for the keyboard which is visible in Steps 27 & 28 this guide 替换MacBook Pro 13‘’Retina显示器2015年早期版本的主板. Did you replace this cable? Or the trackpad cable which is visible in step 29.
这个答案有帮助吗?
得分 0
10条评论:
@danj I replaced the trackpad cable. But the trackpad didn't work, I can see the cursor at the top left corner but doesn't move. Before changing the cable, the only thing working was the power button. After replacing the cable I can see the CAPS light on but clicking it doesn't turn it off or anything, it just stays on. Maybe the trackpad itself is bad?
完成的
@yasserelsheikh - Then the Keyboard cable needs to be checked. Review the steps I pointed to, see if reseating it fixes things.
完成的
@danj Unfortunately it didn't... this cable looks intact as far as I can see. I can see the ZIF connector on the trackpad is cracked (not by me lol) could it be the problem?
完成的
@yasserelsheikh - Post some pics so we can see things.
完成的
@yasserelsheikh - Time to replace the trackpad it’s shot! It’s too much work to replace the connector as it’s to damaged. MacBook Pro 13" Retina (Early 2015) Trackpad
Still need to see the keyboard connector to see what that shows us at the logic board
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Yasser Elsheikh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 224
