跳转到主内容
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
Why doesn't my ps3 display anything on my tv?
I think the HDMI inlet in my ps3 is broken, any guide to fix / clean it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Dennis!
When the HDMI port is broken, you need to replace it by soldering it out, and soldering the new one in.
Guide: https://www.youtube.com/watch?v=bPT9JfUQ...
If this didn't worked, then most likely the HDMI controller is broken on the motherboard.
Does the AV port still work?
Anyway, if you are not sure if your HDMI port is broken or not, you can always sent us some pictures!
Please let us know how it goes!
这个答案有帮助吗?
得分 1
添加一条评论
Try holding the power button until you hear a beep sometimes it is two beeps and your tv should pick up the output. Make sure your tv is set to the hdmi port the ps3 is plugged into as you will only have 30 seconds to confirm this setting before it reverts to the previous setting.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dennis Mutama 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 103
