跳转到主内容
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
20 个问题 查看全部
¿Why my ipad7 is not turning on?
I come here searching for information and help to repair my wife's IPAD 7 WIFI-2019, model A2197. Iam not expert in phone repair, but i want to learn, so i am reading and searching information.
I sent the ipad to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
This is what i found until this moment:
1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
2) no short circuit in lines VCC_MAIN, VCC_BATT.
3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
4) the current draw from the power supply, without battery, is about 26mA from the charging port.
5) i haven't the diode mesurements of the main lines if power, so i dont known if i have a fuge in VCC_main or other line of principal power.
6) i dont know what other test or action i have to do to diagnostic the fault.
I'll appreciate so much your help.
God bless you, and thanks for this forum.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try to go to a store and test a new display,maybe your screen is broken when you repairing and it not turn on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 12
总计 69
