跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch Joy-Con 控制器的维修指南和信息。
Why does my RH controller keep losing connection?
Using my red RH controller it loses connection and re connects over and over. It doesn’t seem to be a battery issue but I haven’t ruled it out.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Chrisa!
The right one does have an antenna connected to it's motherboard. Please open the Joy-Con and check if the antenna is still connected properly to the motherboard. This could cause the random disconnects.
Does the Joy-Con work perfectly fine while attached to the Switch?
Could also be the "Broadcom BCM20734 Bluetooth 4.1/2.4 GHz Transceiver IC"...
This required soldering plus soldering skills to get it fixed.
To test if it's the battery or not, you can also buy a grip holder with USB-C! While it's connected to the cable and still losing it's connection, it's definitely the blue-tooth messing around.
Good luck! And please let us know how it goes!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
chrisa4357 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 13
总计 201
