跳转到主内容
Repair guides and support for wired or wireless devices that provide internet connectivity.
Why my router is suddenly stopped
Plz forgive my English
I'll try to drive the point
I have a problem with my router, it's working but suddenly every five or ten minutes stop working and restart automatically i mean that all LEDs in router include the power lamp turn off and then start again, also another problem in it that all lamps are on but is not blinking not moving and then restart again. Even during write this article it's happened, i really hope that u understood my issue and passed on one of u readers
Forgive me mistakes if i used wrong vocabularies.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @abdallahma34142
What is the make and model number of the router?
Have you tried trying a different compatible, known working power adapter that connects to the router?
Have you tired connecting to a different wall power outlet?
完成的
添加一条评论
1个答案
已选择的解决方案
That's frustrating! Let's troubleshoot:
1. Power cycle: Turn the router off, wait 30 seconds, and turn it back on.
2. Check the power cord and plug for damage or issues.
3. Ensure all cables (Internet, Ethernet, etc.) are securely connected.
4. Restart your modem (if separate) and then the router.
5. Check for firmware updates and install the latest version.
6. Reset the router to its default settings (check the manufacturer's instructions).
7. Check for physical obstructions or interference from nearby devices.
8. If you've recently changed settings, try reverting to previous configurations.
9. If none of the above works, the router might be faulty (consider contacting the manufacturer or a repair service).
Hope this helps you get back online!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Abdallah Mahmoud (Abdo) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 103
