跳转到主内容
加入维修社区 - 创建账户
Xbox One S 是微软于2016年8月推出的电视游戏主机。它是 Xbox One 的改款升级机型。
Xbox one s won't turn on after being turned of for a long time
So I've had this Xbox for quite awhile so it could be age that is causing this but I go through periods of playing and not playing this console so one particular time I had gone to play it after it being off for around a year (could be more or less) and was really confused that nothing would happen when plugged up and the power button being pressed so i opened it up and deep cleaned it (it was quite dusty) but it still didn't work so I'm guessing it's a deeper problem however I can't find anything online that helps with this any ideas? Thank you! Also btw I'm writing this a year or 2 after initially discovering the issue if this matters
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
The first best thing to try is a new power supply to get this fixed!
If it doesn't want to turn on, it's probably the power supply.
If a new power supply didn't fixed it, then return it and ask for a refund. Then it is motherboard related...
Guide: Xbox One S Power Block Replacement
Good luck with the repair, and let us know how it goes!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Scaredapplejuce 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 131
