跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
714 个问题 查看全部
fix for wonky joycon R-button?
About a year ago the R button on one of my sets of joycons started acting up. Sometimes it double presses, sometimes it doesn't register being pressed, and sometimes it gets stuck. I switched to my other pair but now it's having the same problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Noah!
Okay, so the other set of joycons are having the same issue? I still think it's Joy-Con related, because the same issue came up later on and not immediately.
Unfortunately, the right Joy-Con does have the actual button soldered on the motherboard...
Now, there are 2 things to do, to get it working again. If the button didn't fall of the motherboard (this is a common issue for the Right Joy-Con). If this happened, then it's for the best to replace the motherboard.
Option 1: De-Solder the R button from the motherboard and solder a new one in (this can only be done if the traces are still OK).
Option 2: Replacing the motherboard (this is more expensive, but easier).
R button part: https://www.aliexpress.us/item/325680520...
Motherboard part: https://www.aliexpress.us/item/325680689... (A2 is right).
Good luck with the repair and please let us know how it goes!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Noah A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 13
总计 13
