跳转到主内容
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
Why won't my new disc drive read?
After purchasing one of IFixIt's new disc drives and installing it, the disc spins upon startup and then stops, followed by the unable to read disc error. At first I thought it was because I didn't reset the Wii before inserting a disc, but I tried that too with the same result. I'm no expert (have only refurbished two yardsale Wii's in the past), but all of the solders and wiring seems secure, and I can't find any bent or broken pins inside of the connections. While waiting for the disc drive to arrive, I also replaced the thermal pads and gave the entire console a good clean. Could there be something that's not in the disc drive that causes a disc read error?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Regarding your issue it could be multiple things. I had this issue once a long time ago, in this case it was the drive it's ribbon cable. (Drive > Motherboard).
I would replace this one first and see if that fix it.
Good luck with the repair!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
TetriLys 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 112
