跳转到主内容
加入维修社区 - 创建账户
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
Switch Lite won't turn on after battery swap
Replaced the battery in my Switch Lite and now it won't turn on. I tried swapping the battery back to the old one in case I bought a faulty replacement, but it still won't turn on. There's no signs of life when plugging it in with either battery connected. I'd checked all the ribbon cables to be sure they're connected fully and nothing looks obviously broken. Is there any way to troubleshoot what could have gone wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Rachel!
What was the issue before you replaced the battery?
Could be a lot of things causing this. Where did you got the replacement battery from? It's possible that the new battery accidentally damaged the motherboard.
Could be the following IC's which are failing:
  • Maxim Integrated MAX77620HEWJ power management IC
  • Rohm BM92T10MWV-Z USB-C power delivery controller
  • Texas Instruments BQ24193 battery charge management
  • Maxim Integrated MAX17050 battery fuel gauge
Please check those IC's or let them be checked.
Hopefully you will get the Switch working again.
这个答案有帮助吗?
得分 1
4条评论:
Before I replaced the battery the issue was that the battery wasn't holding much of a charge anymore. I've figured out some more info, though -- it does turn on and I can see the screen if I hold a flashlight up to it. The buttons and touch screen respond, but there's no backlight. Trying to figure out now what I need to do to troubleshoot that
完成的
Hi Rachel! Ah good to know that the battery is fine! And that it's probably not motherboard related! The downside is that the screen is having issues now.
There are 2 cables attached to the LCD. The bigger ribbon cable is for the data (this cable is fine) and the small ribbon cable is for the backlight. Please check the smaller ribbon cable attached to the screen! In the worst case, you may need to replace the screen. But hopefully the cable isn't correctly connected.
Here you can see the cables: 任天堂Switch Lite拆解 (Step 10 photo).
And here you can see where it is connected > Nintendo Switch Lite LCD 显示屏更换 (Step 41).
Good luck, hopefully you will get it fixed asap :)!
完成的
Unfortunately, disconnecting and reseating the screen connector on the daughterboard didn't fix things. Is there a straight forward way to figure out if I damaged the screen or the connector on the daughterboard? I have a multimeter if that would be useful
完成的
Ahw too bad. No, not really :(... The best thing to do is to get a replacement screen and test it. If the same issue is happening there, then you can return the screen and ask for a refund. It's the only way to test... sry!
完成的
添加一条评论
添加你的答案
Rachel Sandler 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 85
总计 1,404
