跳转到主内容
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
395 个问题 查看全部
DS4 PCB Short Circuit? (Not Charging)
So I've bought defective DS4 controllers (Not Charging) and thought it was just the charging ports, battery, and flex cables that needed replacement, but it still didn't work, I'm thinking it has short circuit or something? Has anyone fixed the same problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi XeeR!
Is the charging LED coming up? Or not doing anything?
It is something on the motherboard and most likely the s2p6001a IC or a fuse.
More info: https://www.youtube.com/watch?v=Q1C6ymOt...
Please check the IC and the fuses around it. Hopefully you will get them working again!
这个答案有帮助吗?
得分 1
2条评论:
I'll be trying this and update you. Thanks man!
完成的
My pleasure! Good luck!!
完成的
添加一条评论
添加你的答案
XeeR 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 19
总计 19
