跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
Safe mode loop and refuses to update - ps4
I have a ps4 pro with a non working power button so I have to use a disc to turn it on. When I power it up it boots into the safe mode options. I have seen that usually if a PS4 boots into safe mode it would say “cannot start the PS4.” and if you wanted to safe mode options, you would have to boot into safe mode manually. I’ve tried replacing the hard drive. This still happens. I opened it up. It looks fine apart from a little bit of dust. I have tried all of the safe mode options. Most of them require updates. The console refuses to update. When I try to update it says preparing to update then restarts back into safe mode.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Reagan!
Can you share a video with us? Then we can see what is happening.
Please make sure that you use a known working hard drive. And that you use the "PS4 Console Reinstallation file" instead the update only. This one can be found here: https://www.playstation.com/en-us/suppor...
Also make sure that the USB is formatted in FAT32 and that the "PS4" and "UPDATE" folders are created, like this:
Root > PS4 > UPDATE > (Place update in this folder).
Please let us know if this worked.
这个答案有帮助吗?
得分 1
2条评论:
I do have the same issue
完成的
Hi! Did my answer worked?
完成的
添加一条评论
添加你的答案
reagan habib 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 362
