跳转到主内容
PlayStation 3 Slim是Sony Computer Entertainment生产的PS3视频游戏机的第二版。 它于2009年9月1日发布。
477 个问题 查看全部
Bluray drive not taking or ejecting discs all of a sudden
hello, I had a disc in my PS3 slim and the Blu-ray drive stopped working all of a sudden that I had to manually eject it, after that I could not insert or eject discs anymore. the eject button makes the beep sound but no movement whatsoever from the drive! as if the power is not reaching it. I've tested the drive 4pin power cable and the data ribbon cable, both working. I've changed the whole drive and still the same issue.
any ideas what could be the case? I've checked almost everything, with no luck.
thank you,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Ziad!
You already replaced the drive, but the issue is still there? Is the PS3 Slim able to update? If it fails with an update, then it cannot detect the drive.
It does sound like there is an power issue there. Without the ribbon cable, the drive should still take in discs. Without the power cable, the drive won't do anything. When there is no movement at all, it's basically the sensor OR the drive is not receiving any power. In this case it's probably the power cable or either the port on the motherboard which is not supplying the disc drive with (enough) power. Please test the port as well to see if it's powering the drive.
Thanks!
这个答案有帮助吗?
得分 1
2条评论:
the PS3 is working fine other than that, and it's able to update. that's why I guess it's a power issue since there is no movement at all. I will test the port on the motherboard.
thanks
完成的
Hi Ziad! Alright. That's the best thing to do I guess. Please let us know your findings! Thanks :)!
完成的
添加一条评论
I've done some tests around the motherboard, and I could only find that these fuses are not working! I read somewhere that they are related to the blu-ray drive not receiving power!
这个答案有帮助吗?
得分 0
1条评论:
Hi Ziad! Thanks for sharing this information with us!! Good to know that those fuses are responsible for the drive.
Sort of the same issue as the Wii U had with the 160-1400 drive error that was also caused by the fuses on the motherboard.
I recommend to replace the fuses to get the drive working again (you possibly can bridge them to get them working, but I recommend to get new fuses and solder them in).
Have a good one!
完成的
添加一条评论
添加你的答案
ziad isaac 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 41
