跳转到主内容
Required temperature to remove the screen bezel?
I have a general question for all models of MB Air 2010 - 2017
I need to replace some internal cables & hinges but need to know how hot must I set the heat gun to soften the adhesive enough for removal?
And is it possible to replace the Antenna / Wifi cable, can't find any guide on this.... I broke the wire off from the connector on the wifi cable and soldering it back looks like a seriously tricky job https://www.youtube.com/watch?v=UnNCSlU4...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Here’s a good vid on the process MacBook Air LCD repair, how to replace LCD only as far as the heat it doesn’t take much I set my heat gun to 125 Fahrenheit and as seen in the vid holding the air stream over the bezel and away from the rubber edge.
这个答案有帮助吗?
得分 0
3条评论:
Yes seen that, seen the guides in here, I also have a 2009 MBP (The stage lights) that I finally have got a new cable for... the screen is proper stubborn and won't budge a mm even at 150 degrees... IF I go higher I will destroy everything... been heating areas for 20 minutes.... none of them seem to want to budge.
完成的
@livfe - are you using a suction cup to help in lifting? I’ve hit a few hard one’s because someone glued the glass down with the wrong adhesive material or just too much.
Focus on one corner and after you lift it use a playing card to hold it free (if needed cut the card in half or even smaller). Then walk the edge, you may need to raise the temp a bit and even then it can be very difficult because of previous repairs.
完成的
@danj Dan, I know how to get them out, I seen 10 videos on it, It didn't look like anyone was in ther before me, glue was sold. Anyway, screen shattered, and scraping out the residue was a task but now it is clean of everything and the new screen is in, just got to source a new glass.... and the correct longer cable.
The suction cup didn't get into play the glass smashed after I got the 2nd thin plastic tool under it. Glue was sold.
完成的
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 90
