跳转到主内容
加入维修社区 - 创建账户
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
SSD install did not work (software)
I managed to install my Corsair Force III 120Gb SSD in my brand new Mac Mini using the ifixit kit. I then cloned the original HDD to the new SSD and booted from it. All I got was a kernel panic (related, most of the times, but not at every boot, to ACPI).
I removed the SSD and installed it on a Windows machine so to upgrade the firmware to 1.3.3.
I re-installed the SSD in the Mac (by now I can do the job in ~5 minutes) but still no luck. I could only boot in safe mode.
I would therefore advise not to install a Corsair Force Sata III in a Mac Mini because it does NOT work. Also, if it worked, it would suck anyway because I benchmarked it (using the original HDD to boot) and speed is pretty much the the same as the standard HDD.
Has anyone managed to install a Corsair in their Mac mini and if yes, what results did you get?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
This is a 6 GB transfer rate hard drive and your MacMini will only see a 3 GB or less I believe. Jumper the drive to slow it down for it to be seen. There should be four jumper pins and I would try the two to the outside first then try the two to the inside.
这个答案有帮助吗?
得分 2
添加一条评论
Thanks, now the SSD is inside the Mac mini (used as a secondary drive) and I can not check, but I've never seen any jumpers on it. Also the Mac mini is supposed to be Sata III compatible. Also Corsair says the Force III series is fully compatible with Macs. Big bunch of liars.
这个答案有帮助吗?
得分 0
添加一条评论
hmmmmm….
my research shows that all mac minis 2011 and later have 6GB SATA:
ref:
http://www.everymac.com/systems/apple/ma...
and SATA III is the spec for the 6GB interface:
http://www.maximumpc.com/article/feature...
So the incompatibility lies elsewhere. Perhaps the corsair SSD is configurable??
这个答案有帮助吗?
得分 0
1条评论:
It likely needs to be formatted with the correct structure for OS-X: GPT (GUID Partition Table)
完成的
添加一条评论
添加你的答案
pl0634 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 709
