How to change the coolant pipe
Coolant pipe is leaking how to change it plz help
Hey Abdul,
It would help if you could be more specific, the coolant pipe is kind of a difficult one to make out. If possible please respond with the exact year, model and a picture of the location of where it is leaking and i will tell you what needs to be done to repair it. I can not tell if you are referring to a coolant hose, the thermostat housing or the water pump. Your question is a bit to general with not enough information.
I will tell point you to this video for changing a coolant hose in the hopes this is what you are referring to and to make it faster for you to begin to repair. Please let me know the information I asked above and I can help you more.
Replacing Coolant Hose Golf, VW, Audi
I hope this helps!!
Cheers!
Moe
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 32
总计 187
@abdulwahid97176 we need to know the exact year, model,engine size and which coolant pipe you want to change. for your Golf. Give us more information about your vehicle and what the issues are.That way we can give you a specific answer
由 oldturkey03 完成的
