My phone internet doesn't working
When I started internet it doesn't work .
Hi @rohitsaini
Check the data saver setting in the phone is not set to prevent data access.
Go to Settings → Sim cards and mobile networks → Set data plan → Enable Data usage → Data plan.
这个答案有帮助吗?
Restart Your Phone: Sometimes a simple restart can fix connectivity issues.
Check Wi-Fi Settings: Ensure your Wi-Fi is turned on and you’re connected to the correct network. If you are, try forgetting the network and reconnecting1.
Check Mobile Data: If you’re using mobile data, ensure it’s turned on and you have a good signal.
Reset Network Settings: Go to Settings > System > Reset Options > Reset Wi-Fi, mobile & Bluetooth. Remember, this will erase all network settings, including saved Wi-Fi networks and Bluetooth connections.
Update Your Phone: Make sure your phone’s software is up to date, as updates can resolve many issues2.
Restart Your Router: If you’re on Wi-Fi, try restarting your router.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 55
总计 819
no internet connection to my redmi 9A phone
由 David Yawe 完成的
