跳转到主内容
加入维修社区 - 创建账户
现代(Hyundai)于 2012 年 2 月 14 日发布了重新设计的 Santa Fe,并于 2012 年 6 月作为 2013 款车型上市销售。
trunck doesn't open
trunk doesn't open
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @aalaal2
Here are some images that show how to lower the rear seat and open the trunk from the inside, so that it is easier to remove the trunk door trim and access the electrical release mechanism i.e. lock, lock motor etc to see what the problem is.
(click on image)
这个答案有帮助吗?
得分 2
3条评论:
Thank you for the notes on how to open the trunk but I need to open it by pressing the button, how can I do it?
由完成的 分享
@aalaal2
As I said you need to open it manually and then remove the internal trim covering the trunk door so that you can access the lock, lock motor and switch.
Once you can you can check if they're working or not by pressing the button and checking if the voltage signal is being sent to the lock motor to open it etc.
For example have you tried all methods to open the trunk i.e. ignition fob key, central locking button and trunk button
If all three don't work then it may be the lock motor may be faulty. If not it may be a wiring problem between the switch and the bcm (body control module).
Try pressing down on the middle at the bottom of the trunk door and then try open the trunk with the button or key etc. It may be that the lock switch may not be fully operated and this may prevent the lock from working
There's no easy answer for this. You have to know what is or is not happening first before you know where to start looking for the problem.
If you don't have a DMM (digital multimeter) then you may have to contact an auto electrician or a Hyundai dealer.
由完成的 分享
Thank you so much, that is so helpfull
由完成的 分享
添加一条评论
添加你的答案
AAL AAL2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 41
总计 1,329
