跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 个问题 查看全部
USB ports don't work.
After that I installed a new hard drive the two usb ports don't work any longer. When I put in the usb memory it lights up for one or two seconds and then nothing more. There is some contact but not enough to reed it. How do I analyze and fix this problem. I will bee very thankful to get any hint!
Ciao Dick.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Could you connect something else like a usb mouse or a keyboard in your ports ?
完成的
No. If I put in the mouse it get light and it remain. But it give no reaction to the pointer.
完成的
添加一条评论
2个答案
已选择的解决方案
I'm guessing you are refering to a USB flash drive and not system memory. Can you try the flash drive with another computer? Also does this problem exist with more than one flash drive? If the problem is limited to this iBook you may have a problem with your logic board. Good luck. Ralph
这个答案有帮助吗?
得分 1
3条评论:
+ vote for trying to understand this question
完成的
It worked just alright before I changed the hard drive. The logic board seem to be the problem.
完成的
At this point based on your answers I suspect the logic board has a problem. Ralph
完成的
添加一条评论
Did these work on your Mac BEFORE you installed the new hard drive?
Sometimes USB flash drives that have been formatted on a PC don't show up on a Mac, unless you format them on a Mac. If you go into Disk Utility, hopefully you'll see them listed, at which point you can select them and format them (don't do this if they have data on them you want to save), and from that point on they should work on your Mac.
这个答案有帮助吗?
得分 1
3条评论:
I find that usually I can read Windows flash drives on a Mac but can't read a Mac drive on Windows. Ralph
完成的
完成的
Well it was good before I installed the new hard drive. And I could also read Windows formatted flash drives.
完成的
添加一条评论
添加你的答案
Dick 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,139
