Computer suddenly shuts off.
My computer is suddenly shutting off. Can't tell if there's a time pattern for doing so, but the power supply cable is not overheating, nor I have damaged peripherals.
I imagine there's a configuration causing it to lose power or my motherboard may be damaged or short circuiting.
Is there anyone that had the same issue and found an affordable solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
@ticksantana make and model of the computer? What have you checked? What have you tried? IF you do not have a make and model, we need to know your computers configuration. i.e. Motherboard, memory, power supply etc.
完成的
Firstly I thought RAM memory was damaged, yet it was badly inserted, solved the problem for a while, then suddenly the problem started over again.
完成的
@ticksantana I've edited your post to add your pictures; iFixit website comments do not allow for pictures to be posted within them.
完成的
添加一条评论
