跳转到主内容
加入维修社区 - 创建账户
Xbox One X (机型型号 1787)是微软推出的高性能游戏主机,替代 Xbox One S 。这款主机发布于2017年11月7日。
Unit turn's on,but I get no picture on the TV. Replaced the HDMI cable
Not getting picture. Everything else is ok.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Victor!
Well, how is the HDMI port looking? Still good?
It’s common that the HDMI retimer IC is failing.
First I would try the simple tests.
First of all, replace the harddrive for a known working one. Sometimes if the hard drive failed, it wont show you anything (no signal), replacing it should display an image with an error. If this is the case, then the current harddisk failed and need to be replaced.
If you’ve tried this and still no image with a known working one, then take the motherboard out and replace the HDMI retimer IC.
Good luck! Let us know how it goes.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Victor Perez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 127
