跳转到主内容
M2是苹果公司针对Mac的片上系统的第二次迭代,具有集成GPU、CPU、RAM和其他组件,可提高性能和效率。Mac mini中的基础M2有一个8核CPU,有四个高效内核、四个高性能内核和一个10核集成GPU。
Can the Mac Mini M2 be upgraded?
I recently acquired a Mac Mini with the M2 chip. Its the standard base configuration which is not bad for my environment, but I would like to know before I crack it open if the memory is soldered on the motherboard and is the SSD soldered as well. I know some of the later models on their laptops and some imacs/desktops have the ram and SSD soldered on the board. I was just curious if that was the case with the Mac Mini M2.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
Sadly, none of the M series systems are internally upgradable either RAM or Storage as both are soldered in. While there are a few techs with the chops to swap out the Flash chips, there is more to it than simply popping new ones on as they need to be programmed first.
Here’s the Mac Mini M2 拆解 so you can see for your self.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Anthony Ingersoll 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 101
总计 3,490
