Grinder motor not turning on - conical burrs already replaced
Jura C9, worked flawlessly after brew group refresh 3 years ago. Now getting a "Fill Beans" error, no coffee, no grinding. Replaced the conical burr grinder gears and reassembled. Grind motor is not turning on when you try to brew.
Motor is not getting power during brew as verified via a meter. So I'm assuming there is/are 1 or more inline fuses I need to find.
Has anyone run into this problem? Where do you source replacements?
Thank you
UPDATE: In addition to the thermal fuse being bad, I have found board damage on the power control board
2条评论
@bradnic let's see if the iFixit guru @vauweh has a trick up his sleeve ;-) to help you out.
由 oldturkey03 完成的
Thank you @vauweh ! as always. I am delighted to hear there's a repair service in Hamburg. I will try to identify the defective parts myself before sending it out. Fortunately there is no visible trace damage on the board. I have verified that this board is no longer available from Jura. Pics attached (finally figured out how to do that.)
[image|3378616][image|3378617]
由 Brad 完成的
