跳转到主内容
TI-84 Plus calculator support.
Sometimes doesn't turn on, also randomly goes off
I saw the issue for randomly shutting off. I'm not sure if the won't turn on is the same issue or a different one. I can hit the on button and nothing happens, but then after trying a few times, it will come on. It also randomly will shut off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try replacing all the batteries including the backup battery. There could also be a bad connection between the spiral wire contacts that connect the battery to the circuit board. Push gently down on the bottom left and right ones. that may make a more reliable circuit.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
R A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 80
