跳转到主内容
The Samsung Galaxy M51 is an Android smartphone which was released in August 2020.
Galaxy m51 not charging
I have my m51 for over 3 years already, dropped it so many times (cracked like 3 screen protectors), no problems until this year.
Now it was not charging, i tried cleaning the port, any other method that doesn't involve opening up the phone and as a last resort I tried hitting it (stupid idea ik) and after that it charged. After that I've got this problem again a lot of times, hitting it worked.
Now hitting doesn't work, I opened the phone up (first time ever btw), i carefully opened and separated everything until i could see the 2 boards. Carefully inspected both, no sign of damage or anything . Main board flex seems to be fine.
Should i replace both the charging board and the main flex or just the board.
And also before opening phone up i had a problem where the phone was on and screen wasn't showing anything, as always slapping it worked (dont tell me it was the slapping, everything inside looked in perfect condition no damage, at least to my eye).
If fixing it would include micro soldering or anything more expensive than 50$ im just getting a new phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@xz59fe the M series does have issues with the flex cable. I do recommend that you change that as well.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @xz59fe
Here's the troubleshooting guide for the phone.
Go to p.12 to view the cable charging troubleshooting flowchart.
If the charge port board is the problem, search online for SM-M515F USB charging board to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
xz59fe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 37
总计 328
