跳转到主内容
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
Changed battery for OEM, still no power?
Hi, I'm having an issue with getting this Series 2 Controller to turn on. I ordered a replacement OEM battery from Microsoft and replaced it myself.
When I seat the boards back onto the bottom half of the controller it turns on and acts normal for about 10 seconds, then it proceeds to shut off. No buttons can turn it back on and when I plug it in via USB or seat it on its docking station it sits unresponsive with no lights.
When I plug the boards into the USB without seating it on the back half with the battery's it works fine and stays on. There seems to be an issue when seated to the battery.
Has anyone else had this issue or know of possible causes?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Ashton!
My guess is that this didn't happened with the old battery, right?
It just sounds like that the replacement battery is faulty. Return it and ask for a new one OR get a refund.
这个答案有帮助吗?
得分 1
2条评论:
Sorry, yes this was happening with the old one which is why I replaced it. I'm starting to suspect it's the I/O board and may think the battery is overheating?
完成的
No problem! Well that changes it! It could be the I/O board or the motherboard. (my guess it's the I/O board causing this). You can buy the parts here: https://www.aliexpress.us/item/325680306...
完成的
添加一条评论
添加你的答案
Ashton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 116
