跳转到主内容
加入维修社区 - 创建账户
小米 Mi L32M6-EI 电视(也称为小米电视 4A 地平线版 32 英寸)是一款于 2020 年发布的高清(1366 x 768)智能安卓 LED 电视。它搭载 Android TV 系统,内置 Chromecast 和 Google Assistant。
Why my tv gets hang?
I have Mi 32 smart tv, but it's has some issue. Whenever I starts my tv it won't get started but after hours or a day the tv starts but after getting on for above 20 min the tv gets hang, means I can't change the channel or even raise or low the volume, then I have to directly switch off the tv from the plug.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@harshkaran92697 unplug your TV. remove the back cover. Take a look (do not touch) all of the boards and check for any obviously damaged components. Next, take some well focused pictures of all of your boards and post those with your Question. that way we can see what you see. 在已经存在的问题里加入图片
You also need to verify that your TV is a 4A L32M6-E If it is not, let us know what model it is.
由完成的
添加一条评论
1个答案
From what you describe it might be a mainboard issue, more specifically something related to the logic of the TV like the CPU. Given that it takes around 20 minutes to hang, it could be related to thermal stress on the CPU, could be cold or cracked joint on one of the solder balls underneath the CPU, in that case a fix would either necessitate a reflow, reball of the CPU or replacement of the mainboard itself. Of course I cannot assure that without further information, but it would be a good place to start.
From my experience, if a tv shows the standby light and refuses to power on it indicates this type of issue. You might have gotten it to start once or twice by pure luck when the solder joints where making slight contact.
Check out this video of someone attempting a reflow using a hot air gun, keep in mind these are not the proper tools, but If you have nothing to loose and want to give this a shot before buying a new mainboard go ahead! Be careful when working with TV's as they could contain dangerous voltages even after unplugging, only do so if you're comfortable and leave it unplugged for a while.
Best of luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harsh Karangutkar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 18
总计 616
