My Play 4 pro does not read discs
My Play 4 pro does not read discs, it seemed that the discs did not rotate, so I disassembled it and I did not see anything strange in it, so I decided to change the disc drive “Kes-496aaa” and now it tries to rotate the disc, but still does not read them, and I do not know what to do, what could it be?
Hi!
Did you replaced the whole drive? Or did you replaced the laser deck? I know that sometimes replacing the whole drive can give some issues.. And another question, did you also tried a blu-ray movie instead of a game? Just wondering if it can read both or not.
由 koppie007 完成的
Hi @dan0!
That's right, I replaced the whole disk reader, I changed the one that was there for the “Kes-496aaa”, because it was at the same price as if I just changed the pure lens.
And also, I tried with movies and it doesn't read them either, the discs spin a couple of times, but the discs slow down, and then you can hear noise from the lens trying to read the disc.
由 Geo Ragnvindr 完成的
Alright, probably the replacement disk drive is faulty, I’m afraid :(… Usually I change the laser decks for the PS4 consoles. Just to be sure you can also replace the laser cable (laser > motherboard). Better to return it and get yourself a new one. Hopefully you will get back to gaming soon!!
由 koppie007 完成的
Yes, thinking the ribbon cable could be bad as well. When inserting them into their connectors, they have a chance to peel their copper contacts back a bit on certain sections. Have had that issue in the past.
由 Mr.Nimbus 完成的
